Forums >> Revit Systems >> Technical Support >> Walls with automatic wall sweeps
Wed, Aug 29, 2012 at 5:30:03 PM | Walls with automatic wall sweeps
peoshell
This might be a simple answer but I can't fin any info on it.
I need to create a wall family with the sweeps already attached so when I place the wall the sweeps are there without me having to add them in each time.
I've seen this done with other walls but am having trouble replicating it for myself.
Any help would be appreciated.
Ryan
Thu, Aug 30, 2012 at 3:21:49 AM | Walls with automatic wall sweeps
4 Stars: 205 Votes
Look at the bottom of this page and you'll see similar threads about this same issue....
Lots of them.
Fri, Aug 31, 2012 at 2:14:19 AM | Walls with automatic wall sweeps
peoshell
Oh yeah I forgot to mention one think I have to do vertical sweeps. Is that possible?
Fri, Aug 31, 2012 at 3:58:55 AM | Walls with automatic wall sweeps
4 Stars: 205 Votes
What you want (...wall family with the sweeps already attached so when I place the wall the sweeps are there...) only work with Horizontal Sweeps or Reveals, not Vertical.
sweeps and wall styles on sloped walls
Mon, Apr 14, 2008 at 1:28:22 AM
wall sweeps won't clean up
Fri, Jul 11, 2008 at 2:52:46 PM
Wall sweeps
Wed, Jul 8, 2009 at 12:19:56 PM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Page generation time: 2.9211
