Forums >> Revit Building >> Technical Support >> Attaching columns to roofs?
Tue, Jan 10, 2006 at 11:29:59 PM | Attaching columns to roofs?
rgesner
Concrete columns and 1/4"/ft sloping concrete roof: Unless I'm missing something, the only to "attach" the columns to the root is to adjust its offset above the Roof Level so that the top of the column penetrates the roof slab and then to join geometry. This gets tedious because the roof slopes so you can't grab all the columns and adjust at once. Why isn't there an Attach parameter like there is with walls? - Rusty
B. Rustin (Rusty) Gesner, IT/CAD/BIM Director, Mackenzie, Portland, Oregon - Architecture, Interiors, Structural, Planning, Civil, Landscape, Traffic & Project Management
Wed, Jan 11, 2006 at 5:59:55 PM | RE: Attaching columns to roofs?
eldados
eldados Avatar
4.5 Stars: 8 Votes
I was wondering the same thing... Smile you can't attach columns to a roof or floor, but if you think about it, I have never seen the top of a column being slopped to attach to bottom of roof... you will, like you said, have to adjust each column. HTH
Integrator
KarelCAD
Attaching curtain walls to multiple roofs
Mon, Nov 5, 2012 at 2:19:44 PM
Attaching Columns
Thu, Apr 7, 2005 at 11:22:36 PM
Attaching Columns to Footers
Tue, Feb 24, 2009 at 7:34:29 PM
Attaching structural columns to beams - mitered joint?
Mon, Nov 15, 2010 at 3:37:44 PM
Foundation attaching to a columns analytical line
Thu, Feb 11, 2010 at 10:53:59 AM
Page generation time: 0.5260
