14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> old I beam
36 Posts No Rating |
Does any one know where can I get old I beam family, I need to model existing building which all framing members are all I beams, for example 18-I-90, 15-I-55 and drawing I think it around 1920.
Thank you in advance.
Why don't you modify a standard steel family and save it under a new name?
You could also make your own line based objects.
Ditto!
ok, Thank you all, I finnally found the old book of Iron & Steel Beams dated 1873 - 1920, data are so varies from each of manuf. so I just pick one to create profile, incase some one like to use or modify but have to get your own txt file
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection |
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems |
Tue, Oct 21, 2008 at 4:36:54 PM
Beam/joist going through wall |
Thu, Sep 11, 2014 at 4:32:00 PM
