10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> 2nd floor isn't visible in project browser
17 Posts No Rating |
Sometime durring my project my 2nd floor disappered from the browser. I shows up in the elevation veiw but not in the browser. Any ideas on how to fix this? Thanks!!!
Just because you have a level in the elevation doesn't mean you have a corresponding floor plan in the browser.
What color is the target on your level line? Blue indicates it has an associated floor plan. Black means it has none.
the line is black
go to
view/plan view/floor plan select 2nd floor plan and ok
then 2nd floor appered in project browser
FYI, this most likely happened if you "copied" or "arrayed" your level lines up rather than "drew" them using the Level command. They don't automatically get created in the browser if you do it that way.
Rinesh's answer is the solution in case that happens.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
Is there someone who can help me, I can not see my house in building elevation, only the south side. How can I make it visible in the north, east and west?
Click on your elevation marker and pull the view range to include your elements.
Please read about elevations in your HELP.
make sure your elevations and floor plans are all the same phase, like existing or new, because that willl change what is displayed.
Project Browser Sorting Order Question |
Thu, Jul 28, 2016 at 5:01:52 AM
2nd Floor View Range |
Sat, May 29, 2004 at 5:10:04 PM
level not visible in project browser |
Wed, Apr 11, 2007 at 6:09:31 PM
Create sub menu in Project Browser Floor Plan Views |
Tue, Jan 1, 2013 at 8:34:40 PM
Visibility of 2nd Floor in REVIT 2011 |
Sun, Nov 21, 2010 at 8:51:10 PM
