13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> 2D Open Web Joists in Section View
2 Posts No Rating |
I am trying to show a series of open webed steel joists in section view, whithin the structural portion of the floor slab.
Is there a way of adding these in 2D? I can find a 2D detail of the end section of a steel joist but not the whole thing.
I've tried adding a few 3D joists but the become hidden by the floor slab.
Any thoughts?
Thanks
Jon
try making your floor slab transparent.
You have Open Web Steel Joists in a floor slab? How does that work? Can you just hide the floor slab so that you just see the steel?
2 Posts No Rating |
thansks palladio, that worked.
Apologies for the wording, by floor slab I meant floor assembly.
good, glad i could help!
plywood web floor joists and bottom chords of trusses |
Wed, Aug 13, 2008 at 11:39:24 AM
Joists parallel to section cutline don't show in wall section |
Fri, Jan 24, 2014 at 4:23:13 PM
Joists Problem |
Mon, Jan 21, 2008 at 3:09:21 PM
Parametric Open Web Joist Family |
Wed, Oct 24, 2012 at 3:46:30 PM
Sloped framing and framing plans |
Tue, Apr 11, 2006 at 7:47:26 PM
