19 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> No families in Revit 2012
2 Posts No Rating |
Hi,
I am a new Revit user and have recently joined the Revitcity community. I am very eager to get started with Revit but having succesfully installed Revit 2012 I seem to have no families (doors, windows etc)! I have seen similar posts with advise to go to 'Options' in the drop down 'R' tab and correct the path for where the families are located. I have tried this but all the family folders are empty! Can anyone please advise?
Many thanks
Carterred
2 Posts No Rating |
Also when I start Revit this message appears:
the defalult program file you have specified does not exisit : C:\ProgramData\Autodesk\RAC2012\Templates\UK\DefaultGBRENU.rte
to change the default file path , from the applications menu select Options, and thenthe file locations tab.
I have tried this but dont know where to find the correct folders that will load the families. All the folders I come accross seem empty!
I have also uninstalled and reinstalled a few times and still nothing!
I'm not sure about the installation process so I don't know what you did wrong. If you did install the families (I think there may be an option not to), then you can do a windows search and find the correct path. IF you can't find them, then it looks like you need to re-install.
Downgrade families from 2014 to 2012 |
Fri, Sep 18, 2015 at 2:58:53 PM
Renaming OOTB Revit Families in 2012 |
Thu, Jul 5, 2012 at 9:37:41 AM
Revit Architecture 2012 Library? |
Sat, Sep 1, 2012 at 11:21:01 AM
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2012 crashes at splash screen HELP!!! |
Fri, May 17, 2013 at 1:13:24 PM
