Forums >> Revit Building >> Technical Support >> Deleting Rooms
Sun, Aug 26, 2012 at 3:33:05 AM | Deleting Rooms
archisot
Hi,
it seems that i have a big problem with the Rooms.... i tried before to use the Room separation Lines
i want to delete all the Rooms tha i have on my project and all the seperation lines that i used before...
I went to the Room Schedule and deletet the rooms... but after i tryied to see if the room ecxistet.... it was still there... i mean i choose the room and pass my censor above the place where a room used to be and it was still there
What did i do wrong?
Thanks
Sun, Aug 26, 2012 at 3:49:37 AM | Deleting Rooms
archisot
i have forgot to say that i already deletet all the schedules...but the Rooms are still there
Sun, Aug 26, 2012 at 7:38:40 PM | Deleting Rooms
agosztyla
did you use a shortcut. ive read that the autocad shortcut for delete is the same as hide for revit. if you room sep lines are invisible hit you little light blb select your line right click and select all in project
Sun, Aug 26, 2012 at 8:47:46 PM | Deleting Rooms
Polar
Hi archisot,
you need to make a new room schedule, add area, name and number to your schedule
then delete them from your schedule using the delete button
next go to a plan view where the room separation lines are visisble
select everything
use the filter to select only room separation lines (unfortunately you may not be able to right click and select all)
delete all of the room separation lines at once
110303_delete_rooms.PNG110303_deleted_room_plan.PNG110303_deleted_room.PNG110303_how_to_select_all_room_separation_lines.PNG
think it - build it
Deleting Rooms from Schedules
Tue, May 8, 2012 at 8:30:32 PM
Deleting Rooms Permanently - 2009/2010/2011
Fri, Jan 28, 2011 at 7:42:47 AM
DELETING ROOMS WITHOUT VISIBLE TAGS
Thu, May 4, 2006 at 6:59:11 AM
Copy/Monitor Architect's Rooms
Mon, Mar 3, 2008 at 5:37:48 AM
Can't delete not placed room
Wed, Sep 24, 2008 at 7:48:49 PM
Page generation time: 1.9106
