Forums >> Revit Building >> Technical Support >> pattern based curtain panel
Fri, Aug 24, 2012 at 10:48:19 PM | pattern based curtain panel
shijian12
Good Evening!
I am pretty new to revit. I am using revit 2013 learning how to divide surfaces of a mass and apply panels to the surface. I made a new family of pattern based curtain panel and load it into the project. However, the panels stay in the mass and would be turned off when mass is turned off. Also, all the panels stay together and can not be changed / edited individually. I tried loading the panels from the library, and encounter the same problem. Please help and advise.
Thank You!
Edited on: Fri, Aug 24, 2012 at 10:52:37 PM
Sat, Aug 25, 2012 at 5:28:51 AM | pattern based curtain panel
4 Stars: 205 Votes
You can learn with this guy (Zach Kron): http://buildz.blogspot.pt/
Sat, Aug 25, 2012 at 1:16:10 PM | pattern based curtain panel
shijian12
Hello, that does not seem to answer my question which is probably more basic. I followed different online tutorials and yet each time the panels stay withing the mass. Could this be done at all?
Curtain panel pattern based CORNER
Sun, Nov 1, 2015 at 8:10:30 AM
revit 2013. curtain panel pattern based
Sun, Jan 20, 2013 at 9:11:09 AM
Building Arabic style panel
Tue, May 26, 2015 at 9:48:09 AM
Pattern Based Panel - Curved Issue v2015
Tue, Feb 2, 2016 at 7:09:07 PM
Pattern Based Panel - Rotation Error
Tue, Feb 16, 2016 at 9:35:06 PM
Page generation time: 0.2996
