Forums >> Revit Building >> Technical Support >> Can't Remove Paint from Stair
Fri, Aug 24, 2012 at 2:51:17 PM | Can't Remove Paint from Stair
stealthnyc
4.5 Stars: 2 Votes
Hi Everyone,
I'm using Revit Arch 2012. I used the paint tool on a couple of surfaces on stair treads/risers and now when i try to use the Remove Paint tool nothing happens.  I can repaint the areas with the same material but then if i try to change the material set up for the tread in the stair properties, the painted areas stay the same.  Can anyone else confirm this or let me know what I'm doing wrong or how to fix it back.  Thanks!
Mon, Aug 27, 2012 at 9:12:13 AM | Can't Remove Paint from Stair
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Good question.  I have never tried to paint a stair before but I just did and I also cannot remove the paint.  I tried to do it in a 3D, Section, Camera, Plan views and nothing seems to work.  May be a bug in 2013??  My suggestion would be to redraw the stair and use actual materials rather than painting.
Mon, Aug 27, 2012 at 1:47:00 PM | Can't Remove Paint from Stair
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is a response that I recieved from Autodesk...
" This is a known issue and is loged with our development group for investigation. The painted surface will have to be "repainted" to the original material. The remove paint tool does not work on stair elements."
Tue, Aug 28, 2012 at 8:01:37 PM | Can't Remove Paint from Stair
stealthnyc
4.5 Stars: 2 Votes
Thanks teafoe5.  The reason I was doing it was because the designer wanted a stone tread with an exposed metal plate on the
sides.  And painting the side was easier than trying to model the plate on both sides.
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
WALL CUT (openings) MATERIAL
Sat, Sep 28, 2013 at 10:56:04 AM
Paint material to stairs soffits
Tue, Oct 31, 2017 at 6:50:59 PM
Stair Material Takeoffs - Volume Calculation Error when Painting
Tue, Dec 10, 2013 at 7:45:46 AM
stair sections and hidden lines
Wed, Jul 27, 2005 at 3:02:29 AM
Page generation time: 2.4779
