Forums >> Community >> The Studio >> Residential BIM model
Tue, Jan 10, 2006 at 1:38:54 PM | Residential BIM model
mbmckay
I am an architecture professor looking for a BIM model of a residential house for academic use......would anyone know where i could get one? Thanks Michael
Tue, Jan 10, 2006 at 6:11:15 PM | RE: Residential BIM model
eldados
eldados Avatar
4.5 Stars: 8 Votes
sorry mate, I don't do residential... Smile you could put a simple house together very quickly though. can you use Revit?
Integrator
KarelCAD
Tue, Jan 10, 2006 at 6:23:30 PM | RE: Residential BIM model
TomDorner
4.5 Stars: 25 Votes
Same here...don't do residential. If you are an instructor teaching Revit you might be able to get a sample house through Autodesk. Tom
Tue, Jan 10, 2006 at 11:24:14 PM | RE: Residential BIM model
KalH
there is an excellent book on Residential using Revit: "Residential Design Using Revit Building 8" by Daniel John Stine worth to get it...give it a try you might end up having your residential model! Hope that helps, Kal
Wed, Jan 11, 2006 at 12:21:46 AM | RE: Residential BIM model
jobcaptain
jobcaptain Avatar
1 Stars: 2 Votes
I'm an instuctor certified with the State of Wisoonsin. Consider going to this page to get Revit courseware with datasets that you can use in your classroom. While this CD is availabe to instructors in the US/Canada, there is an email address to contact an educational dealer in your country. Check out the listings on the left side of the screen on this page for additional courseware and datasets that you can download and might meet your needs. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4356896 If you have Revit, there are tutorials that ship with the product that you can access through the HELP pulldown menu. There are a few residential models included that would eliminate starting from scratch. If you don't have Revit, you can download and install a trial version from the Autodesk website. Cheers to higher learning! Revit Blogs: www.taylor-tech.com/danielhughes http://www.cadgrafx.com/blog/revit/
LinkedIn Profile:
  • http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com
Why Revit for BIM on Residential homes
Fri, Jan 13, 2017 at 12:42:17 AM
elevator BIM model
Fri, Sep 14, 2012 at 4:04:11 AM
How to model residential garage slab on grade with slope and stem walls
Thu, Oct 10, 2013 at 3:30:52 PM
MS project plan connectivity in REVIT for BIM model
Wed, Sep 3, 2014 at 3:36:55 AM
BIM 360 Link Issues
Wed, Sep 12, 2018 at 12:10:50 PM
Page generation time: 1.8739
