Forums >> Revit Building >> Technical Support >> Irregular residential roof
Thu, Aug 23, 2012 at 10:00:10 PM | Irregular residential roof
tectacoma
tectacoma Avatar
Revit 2012
I;m trying to re-create the roof of this residential project - see pictures below. I could really need some good advise here guys..
I'm at my wits end...Sad
 The roof ridge is not centered as you can see from the aerial pic
Problems:1. I can't join the roofs with the join/roof command. "ErrorPuhart of the roof to be joined misses the target face."
2. The gable/California roof does not come out correctly either
3. I tried to create the roof in 3 different pieces but can't get it to work...basciall I can't re-create the roof at all as of now.
Please...let me know if you have any ideas...
thanks
Fri, Aug 24, 2012 at 4:30:00 AM | Irregular residential roof
4 Stars: 205 Votes
You can create that roof (by footprint) in two pieces only, no need of that and the gable roof will join to the main roof, create the main roof by the perimeter ( "L" shape) you have then you can change the slope and height / offset position of each eave.
Fri, Aug 24, 2012 at 6:14:29 AM | Irregular residential roof
Khuongledinh
Khuongledinh Avatar
1 Stars: 1 Votes
In my idea, you must create two roof by footprint.
The large roof below you create and define the slope, define the plate offset from base for four side of the sketch if they are different height. Then finish
The small roof above you create the same the large roof, just change the height offset of the roof from base. Then finish
Now goto 3D view, goto Modify -> Join/unjoin Roof. click on the edge gable of small roof and click on the plane of the large roof you want to join.
After all, you go to Home ->see opening section -> click vertical opening -> choose the roof -> and sketch the region you want to open/eliminate the part of the roof you want.
Fri, Aug 24, 2012 at 8:21:00 AM | Irregular residential roof
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Typhoon is correct, you only need 2 roofs byu footprint and just use an offset to get the high level (or low level) that you want and then use the join roof command after both roofs are created to get them to join together.
Fri, Aug 24, 2012 at 12:07:40 PM | Irregular residential roof
tectacoma
tectacoma Avatar
Revit Masters....thanks so much...this is what happens when you stare to long at the forest.
"I can't see the forest because of all the trees in front of me"
Again, thanks so much for you help guys. Smile
Fri, Aug 24, 2012 at 10:22:08 PM | Irregular residential roof
tectacoma
tectacoma Avatar
Follow up question:
I managed to slope the roof and adjust the plate height...thanks for pointing that one out.
When I tried to join the 2 roofs I either get the error message - can't join roofs;
or
when I managed to join it only manages to join part of the roof (I actually changed the plate height -1' to get this one)
@Teafo5...I saw what you did and managed to do the same in the past but for whatever reason I can't get same results...
See attached pics below
Please let me know if you can think of anything that I'm not doing right...thanks
Edited on: Fri, Aug 24, 2012 at 10:19:17 PM
Edited on: Fri, Aug 24, 2012 at 10:20:55 PM
Sat, Aug 25, 2012 at 5:43:33 AM | Irregular residential roof
4 Stars: 205 Votes
I can open those PDF's but not the images, I can save them but when I open them they are very small and I can't see the problem....
Sat, Aug 25, 2012 at 10:21:13 AM | Irregular residential roof
tectacoma
tectacoma Avatar
Typhoon, try these images...I "print screen" and used photoshop..hope you can see it better now. When I click on the images
below here they open jjust fine in another window.
I can't get the roofs to join correctly..only partial
Thanks for helping out again.
Sun, Aug 26, 2012 at 5:34:36 AM | Irregular residential roof
4 Stars: 205 Votes
Nope, still can't.... Use free softwares like "Screenhubter" or "JING" to capture images like this...
Anyway... are you using the "Join/Unjoin roof" tool or the "join/Unjoin" tool ? there's a difference here...
Use the first... now select the edge of the gable roof then select the FACE of the MAIN roof...
Sun, Aug 26, 2012 at 4:27:13 PM | Irregular residential roof
Polar
Hi Tectacoma,
Typhoon is right, but you have to do a little bit of fancy foot work.
Your main roof has to extend down far enough with the valleys at an angle in your roof by footprint sketch.
I have a attached a few freehand sketches here...
In general I think the best way to go is to make the main roof too big to start, then join the roof of the gable end like you have done correctly, and last go back and edit the sketch of the main roof by picking the valleys of the gable roof and then offsetting just enough so that the roofs can stay joined. Trim to tightly and their won't be enough of the main roof left to extend and attach to.
think it - build it
Sun, Aug 26, 2012 at 4:51:12 PM | Irregular residential roof
#11
Polar
Tectacoma,
The attached snapshots so the way you might edit the roof sketches to achieve the effect you're trying to create.
110300_roof-question-a-05.PNG110300_roof-question-a-08.PNG110300_roof-question-a-10.PNG
think it - build it
Sun, Aug 26, 2012 at 11:35:34 PM | Irregular residential roof
#12
tectacoma
tectacoma Avatar
Mon, Aug 27, 2012 at 3:55:40 AM | Irregular residential roof
#13
rinesh355
rinesh355 Avatar
4 Stars: 5 Votes
check attachments
this revit file may help you
Irregular roof
Mon, Jul 12, 2010 at 2:48:47 PM
Please Help-Revit 2011-Creating a single sloped roof
Tue, Nov 8, 2011 at 2:50:01 PM
Residential Roof - Can't join plan pitch with gable
Wed, Aug 9, 2017 at 10:00:27 AM
Is there a way to subtract roof geometry from wall - Take a look at attachment
Thu, Feb 9, 2012 at 2:59:43 AM
Irregular Ceiling
Mon, Aug 4, 2008 at 1:45:52 AM
Page generation time: 0.9979
