Forums >> Revit Systems >> Technical Support >> Pipe crossing gap mystery
Thu, Aug 23, 2012 at 12:01:47 PM | Pipe crossing gap mystery
jlights
3 Stars: 2 Votes
We are using MEP 2011 on a project with arch and structural linked models. The ouside pipe gap setting is 1.6. The view is set to Coarse and Hidden Line. In MEP Settings, the line style is MEP Hidden. On the lower level views, the gap displays properly. However, on the upper level views, the gap only displays if the arch and structural links are turned OFF in the view. See screen shots attached. "Links on in lower level view" shows the gap working properly in one of the lower level views where both links are ON.
Any thoughts on what might be causing this?
thanks!
jlights
Pipe Crossing Display
Wed, Jul 21, 2010 at 1:01:30 PM
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:16 PM
Welds in Possibly Coding?
Tue, Dec 23, 2014 at 9:36:32 AM
Help! Revit highligts (floors/roofs/topo) Doesn't allow Crossing Window
Tue, May 20, 2014 at 10:16:20 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Page generation time: 0.0771
