Forums >> Revit Building >> Technical Support >> View Overlay Order on Sheets
Thu, Aug 23, 2012 at 8:38:32 AM | View Overlay Order on Sheets
cboersen
I have two views on one sheet and they overlap a bit. In Revit I can see all of both views (as though transparent) but when plotted one view is obscured by the other. I do not mind the obscuring so much but the wrong view is being obscured. I want to change which view is "on top" of the other. Is there a way to change plot order or view order of views on a sheet?
Thu, Aug 23, 2012 at 8:48:49 AM | View Overlay Order on Sheets
Experiment with when they are placed on the sheet - I'm sure that is your solution.
Thu, Aug 23, 2012 at 9:38:32 AM | View Overlay Order on Sheets
cboersen
I thought of that also, but it makes no difference ... the placement order or the view number.  One view is a plan view and the other is a 3D view ... the 3D always plots "under" the plan view.  Any solutions?
Thu, Aug 23, 2012 at 10:42:01 AM | View Overlay Order on Sheets
I had not looked at this for awhile so I checked it out.  One view does not print overtop of the other - they both print.  I'm not sure what affect masking regions might have.
Wed, Mar 25, 2015 at 2:53:03 PM | View Overlay Order on Sheets
ccottongim
Is there a way to overlay views on a sheet and then set the order?  I don't think i've seen an answer.  Masking regions don't seem to be available when setting up views on a sheet in Revit 2015.
CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
Tue, Aug 5, 2008 at 1:18:31 PM
sheet index order with Linked models
Sun, Mar 13, 2016 at 12:37:27 PM
Plot Order
Tue, Jan 3, 2012 at 9:40:18 AM
Drawing list sheets are in incorrect order
Fri, Jul 9, 2010 at 10:59:05 AM
Rendering with wire frame overlay
Wed, Nov 26, 2008 at 4:38:33 AM
Page generation time: 1.4089
