Forums >> Revit Building >> Technical Support >> walls with 2 hatches solid/pattern
Thu, Aug 23, 2012 at 2:57:52 AM | walls with 2 hatches solid/pattern
bobthebuilder22
In order to clearify the fire rating of my walls i have 2 catagories of filters applying to different wall parts.
So i have a pattern for 1 criteria and a colour (solid fill) for another criteria.
now the problem is that if i do this in VG filters, then i can only see the top filter since most of these filters apply to the same walls.
Only way around is to only use 1 filter and place regions ontop of the walls for the wanted result.
Is this really the only way?
Ofcourse i only want this type of behavior on the fire rating drawings so it should be done somehow with filtering.
im using revit 2012 and 2013
Thu, Aug 23, 2012 at 7:27:21 AM | walls with 2 hatches solid/pattern
I would look for a different process.  BTW - You should goto the AUGI site and vote on the official wishlist.  One of the items is a proccess for showing wall ratings.
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Solid Fill Pattern
Wed, Jan 9, 2008 at 1:55:24 AM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:47 AM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Bearing walls solid fill
Tue, May 17, 2005 at 10:54:56 AM
Page generation time: 0.5056
