Forums >> Revit Building >> Technical Support >> leader note line
Wed, Aug 22, 2012 at 2:04:25 PM | leader note line
Warchitect
4 Stars: 5 Votes
Is it possible to completely disable the choice to put the leader line on the bottom line of a text?
I hate that option (dont think anyone uses it) and it seems to reset itself all the time.
Wed, Aug 22, 2012 at 2:16:28 PM | leader note line
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Revit defaults to the last command used.  So click on Text, then where you want the leader line located, then place your text and the next time you go to make text your previous selections are recalled.
Wed, Aug 22, 2012 at 2:18:01 PM | leader note line
There is no way to turn it off.  If you pick where you want it when you start a note, it will reset to that.  Picking it after the note is started only changes that instance.
I use the bottom for left side notes ... which are right side justified.  I could never figure out why some people want the leader to come from somewhere in the middle of a note like you like.
Leader Lines not attached to Coded Note [ 1 2 ]
Wed, Feb 4, 2015 at 12:06:12 PM
16
Manipulating the Leader Line
Mon, Jan 2, 2012 at 11:05:14 AM
Adding Snaps to Leader Lines
Thu, May 29, 2014 at 7:34:34 AM
Callout Leader Line Straightening After Placing
Fri, Jan 22, 2016 at 3:36:22 PM
Leader Line Line weights
Sat, Feb 7, 2009 at 10:47:57 AM
Page generation time: 0.7865
