Forums >> Revit Building >> Technical Support >> Project Opens Unresponsive
Wed, Aug 22, 2012 at 8:18:20 AM | Project Opens Unresponsive
Mattburn87
Frequently, when I open a project, the project is uneditable. I can pan, zoom, and open views, but cannot select. Also, to close Revit, I must do so by ending the process from windows task manager. I'm currently using 2013, but the problem was also present in 2012. Usually a restart of Revit clears the problem for that session.
Have any of you experienced the same problem and have found a solution?
Wed, Aug 22, 2012 at 8:30:53 AM | Project Opens Unresponsive
Are you opening Revit then the project or just double clicking on the file?
Wed, Aug 22, 2012 at 8:36:03 AM | Project Opens Unresponsive
Mattburn87
I open Revit first.
Wed, Aug 22, 2012 at 8:42:32 AM | Project Opens Unresponsive
No suggestions then other than audit your file and make sure you have the latest Revit build.  In addition - have you cleaned your system?  Use something like 'CCleaner' to clean up your temp files.  This is often a source of problems.
Unresponsive View
Fri, Jun 18, 2010 at 9:14:11 AM
Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Fri, Jan 13, 2012 at 11:29:51 AM
Clicking on a file to download automatically opens it in revit - How to stop it?
Tue, Aug 18, 2009 at 8:42:42 AM
Strange Error Revit Server only at one Site
Tue, Jun 17, 2014 at 2:47:51 PM
New Session Opens Automatically
Thu, Feb 10, 2011 at 10:58:13 AM
Page generation time: 7.9452
