10 Users Online (8 Members):
Forums >> Revit Structure >> Technical Support >> Total Weight for Steel
1 Posts No Rating |
I am trying to setup a formula in my Structural Steel Schedule that will let me multiply the length of the beam by the weight of the beam to get the total weight of the beam for take offs. If anyone can help me with this it would be greatly appreciated
Please start by reading the similar threads below:
The Weight parameter attached to structural members is unitless so when you try to multiply Length X Weight, revit gets confused. You'll simply have to add something into your formula to cancel out the units all together. Try this:
Cut Length / 1' * W
can you get tonnage or weight from the schedules command? |
Fri, Feb 19, 2010 at 3:15:23 AM
Steel weight |
Thu, Sep 4, 2008 at 5:55:14 AM
Schedules for Steel Tonnage |
Thu, Oct 29, 2009 at 8:48:44 AM
Possible to assign weights to Revit Familys? |
Mon, Mar 17, 2014 at 9:03:50 PM
sloped steel? |
Thu, Apr 8, 2010 at 5:51:25 PM
