Forums >> General Discussion >> Revit Project Management >> putting curtain Wall in legend
Tue, Aug 21, 2012 at 6:13:10 AM | putting curtain Wall in legend
mhbn4
2.5 Stars: 4 Votes
Hi everyone
Please help me for puting curtainwall into legent sheets
Tue, Aug 21, 2012 at 7:01:44 AM | putting curtain Wall in legend
You can put curtain wall components in a legend but not curtainwalls.  We elevate each unique CW separately using a callout from the elevation (which we hide).
Tue, Oct 30, 2012 at 3:52:09 PM | putting curtain Wall in legend
nematsvehclav
5 Stars: 2 Votes
This is ridiculous. Why on Earth would one be able to put all sorts of walls as legend components, but curtain walls? Simply has to be fixed...
Tue, Oct 30, 2012 at 4:14:34 PM | putting curtain Wall in legend
This is NOT ridiculous!  Curtain walls are not individual items like walls are and they need to be elevated to properly show them.  If you look, you can't do elevation legends of a wall either, just plan and section legends.
If curtain walls were fixed elements like walls are, then they would have already created the ability but they are not defined that way.
Tue, Nov 13, 2012 at 3:03:23 AM | putting curtain Wall in legend
mhbn4
2.5 Stars: 4 Votes
thank you so much
Mon, Mar 7, 2016 at 5:49:23 PM | putting curtain Wall in legend
gpktm
gpktm Avatar
YES IT IS RIDICULOUS. It doesn't matter what curtain walls are, it matters how they been used in the drawing principles. The program cannot dictate the drawing principles, the program must be dictated by them. Simple as that. So don't say is not ridiculous trying to justify a program that is full of workardounds because lazy Autodesk is a "monopoly" and they don't listen to their customers request. Say "yes is ridiculous, but... (and try to explain the reason)"
Tue, Mar 8, 2016 at 2:40:35 AM | putting curtain Wall in legend
Bartholomew
5 Stars: 2 Votes
LOL! So, gpktm, what you’re saying is:  if you can’t hammer a nail with a screwdriver, it’s the screwdriver’s fault.  Hmm…
Revit is a toolbox. That’s all it is, dude.
Fri, May 4, 2018 at 11:06:15 AM | putting curtain Wall in legend
Thread Post Kudo! #8
Anthiv
If you convert curtainwalls into Assemblies, then you can add them as legend components.
Tue, Sep 8, 2020 at 2:10:50 PM | Anthiv
palydezign
Quoting Anthiv from 2018-05-04 11:06:15
Brilliant, thank you very much for you valuable answer. You seem to be the only one out of the above who knows the software well. Very much appreciated
Tue, Sep 8, 2020 at 3:03:59 PM | putting curtain Wall in legend
paldezign,
Be careful about your deductions.  I see that you are new to this site today and probably fairly new to Revit.
Many of us here have been around a lot longer and have watched Revit get better with every release.  Assemblies were first introduced in 2012, the year this thread was started.  Quite frankly, I can not remember the functionality of that new command at that time since it was 8 years ago but even then it was not what it was just a year later yet alone today.  As an example, here is how it ws changed in 2013: https://www.ideateinc.com/blog/2012/05/new-parts-and-assemblies-functionality
Also in many offices, we were reluctant to fully adopt a new release until enough of the bugs were worked out.
So again, be careful about throwing stones and I hope you become a good CONTRIBUTING member.
Curtain Wall Door as Legend Components
Mon, May 19, 2014 at 7:55:50 PM
wall intersection with curtain wall
Mon, Apr 14, 2014 at 10:48:38 AM
Curtain Panel Legend - 2008
Tue, Jan 22, 2008 at 7:18:18 PM
Hiding Legend Notation
Tue, Jun 25, 2013 at 10:25:19 AM
Wire Mesh curtain wall?
Fri, Oct 24, 2014 at 1:21:59 PM
Page generation time: 1.9085
