Forums >> Revit Building >> Technical Support >> Exterior Wall Recesses
Mon, Jan 9, 2006 at 5:11:07 PM | Exterior Wall Recesses
rcollins
I'm trying to create EIFS panel in brick wall. Needs 4' wide rectangular bottom with 2' radius arch top. It also calls for soldier brick forming a 180 deg. eyebrow top. Any hints will be helpful Thanks.
Mon, Jan 9, 2006 at 6:50:58 PM | RE: Exterior Wall Recesses
eldados
eldados Avatar
4.5 Stars: 8 Votes
create it as an external generic model wall base, you can assign parameters for the arch top (if you want to) as well assign the brick material to the arch. it will be a combination of solid and void extrusion... HTH
Integrator
KarelCAD
recesses in slabs
Thu, Sep 29, 2005 at 3:33:42 AM
Wall Recesses
Fri, Jul 9, 2010 at 9:49:00 AM
Recesses & Vertical Reveals
Mon, Dec 22, 2003 at 4:26:56 PM
Exterior finish on wall not exterior enough... ?
Fri, Jun 3, 2011 at 8:44:28 PM
roof detail after exterior wall
Thu, Apr 1, 2010 at 11:34:56 PM
Page generation time: 0.5330
