Forums >> Revit Structure >> Technical Support >> Continuous Wall Footing ?
Mon, Aug 20, 2012 at 12:19:36 PM | Continuous Wall Footing ?
seniorcad143
1 Stars: 1 Votes
Can you do a wall footing with no wall on top of it, or do I have to call it a grade beam?
Also - How can I do a cont footing in the interior of a building, down 8" from finish floor, where the slab pours down on top of it and it is centered under a wall above?  (I would like to use the wall footing because it would be faster and then I can monitor the walls fron the architect and if the wall location changes then my footing could change.)
Yeesh - Where is My Cad
Thu, Aug 23, 2012 at 9:33:12 AM | Continuous Wall Footing ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"Can you do a wall footing with no wall on top of it, or do I have to call it a grade beam?"
You need a wall to host a wall footing
"the slab pours down on top of it and it is centered under a wall above?"
 Are you talking about a thickened slab edge?
Thu, Aug 23, 2012 at 10:05:40 AM | Continuous Wall Footing ?
seniorcad143
1 Stars: 1 Votes
Well it could be a thickened slab edge coming in from both ways because the slab runs across the footing.
But I would like to link the footing with the wall somehow so that if the wall moves the footing will move with it.
Thu, Aug 23, 2012 at 10:44:03 AM | Continuous Wall Footing ?
I don't use structural so ....
You might try a slab footing then dimension from that to the wall horizontally - lock it and delete the dimension.
Thu, Aug 23, 2012 at 10:59:31 AM | Continuous Wall Footing ?
seniorcad143
1 Stars: 1 Votes
That sounds good - other than do you mean for a slab footing use a concrete beam?
(Is there a "so called command" for a slab footing that I don't know about - I am pretty new to Revit?)
Thu, Aug 23, 2012 at 11:03:57 AM | Continuous Wall Footing ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could use a beam but I would probably use the SLAB tool to create it.
Thu, Aug 23, 2012 at 11:11:01 AM | Continuous Wall Footing ?
seniorcad143
1 Stars: 1 Votes
Taefoe5 - are you talking about using the slab tool to create the footing?  If so, how?
Thu, Aug 23, 2012 at 12:16:24 PM | Continuous Wall Footing ?
OK - Not Slab footing - Foundation Slab
Thu, Aug 23, 2012 at 12:28:56 PM | Continuous Wall Footing ?
seniorcad143
1 Stars: 1 Votes
Yes, I know about the slab edge, but I really need the slab to keep going and angle (pour) down to the footing from both sides.
Thu, Aug 23, 2012 at 12:52:22 PM | Continuous Wall Footing ?
Hello.... have you thought about a simple sweep in the floor category to do the drop.?  That could have the shape you want and be tied to the wall.  And still use the "Foundation slab"<< Not slab edge.
Slab edge could work put you would have to split your floor in two and it would not flex with the wall.
Thu, Aug 23, 2012 at 1:16:51 PM | Continuous Wall Footing ?
#11
seniorcad143
1 Stars: 1 Votes
I think the sweep might be the answer.  I don't want to put in 10 milliondifferent slabs (UGH)!
(I will try the dimensioning the footing to lock it to the wall and then the sweep.)
Thansk!!!
Thu, Aug 23, 2012 at 1:27:47 PM | Continuous Wall Footing ?
#12
If you have a gazillion of these, then make a simple extrusion or sweep family.  Don't do an in-place.
Thu, Aug 23, 2012 at 1:57:50 PM | Continuous Wall Footing ?
#13
seniorcad143
1 Stars: 1 Votes
Yes I will - I have done a few before, now only to check my memory bank on how to do that.  :-)
Thanks!
Thu, Aug 23, 2012 at 1:59:47 PM | Continuous Wall Footing ?
#14
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Think you are on the right track, with the sweeps, especially if you are doing infill type structure, which can have multiple steps in the slabs etc. preparing a footing profile system prior to commencing could help so that they will all fit together easily. Good luck.
Continuous footing off center from host wall?
Wed, Mar 29, 2006 at 11:46:48 AM
Stepped Footing
Sun, Nov 7, 2010 at 7:35:38 AM
Footing longer than the wall
Thu, Oct 27, 2005 at 2:48:42 AM
continuous footing
Wed, Jul 15, 2015 at 12:17:37 PM
Continuous footing under door openings
Thu, Feb 12, 2009 at 11:33:30 AM
Page generation time: 2.7058
