Forums >> Revit Building >> Technical Support >> formula for range of a dimension
Sun, Aug 19, 2012 at 8:34:25 PM | formula for range of a dimension
vidhikholia
This can be silly for revitgeeks...
How could we use a formula for a range of length of an element itself?
eg. length between 3m to 5m
Mon, Aug 20, 2012 at 1:44:34 AM | formula for range of a dimension
frifer
5 Stars: 4 Votes
do you want to see if a length is between two values or do you want to set a length to any length between two values?
in the first case its easy, just use 2 nested ifs, but i doubt that this is the real question, the second case doesnt even make too much sense to me.
in case you want to see if the length is between 2 values try it like this:
if (length > 3000, if( length < 5000, TRUE, FALSE) , FALSE)
or
if (AND (length > 3000, length < 5000),TRUE, FALSE)
regards
igor
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Revit Reporting Parameter
Wed, Aug 7, 2013 at 11:17:04 AM
Controlling Yes/No Parameters with Formula
Thu, May 29, 2008 at 7:53:19 AM
basic formula question regarding parameter use
Wed, Jun 16, 2010 at 5:34:23 PM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Page generation time: 0.2223
