Forums >> Revit Building >> Technical Support >> Demo door but not the frame
Fri, Aug 17, 2012 at 7:55:42 AM | Demo door but not the frame
dwhit104
In Revit 2012, i need to show the door being removed, but the frame is to remain. How do I do this?
Fri, Aug 17, 2012 at 8:21:08 AM | Demo door but not the frame
This is one of those things that is not easy to do unless the door family was built to allow for it.  The way I would do it is to use the linework tool.   In the demo plans, use the tool on the door and swing lines with your dashed demo line.  On all other new plans, use the tool with invisible lines.  The problem is ... every plan.
Edited on: Fri, Aug 17, 2012 at 8:21:28 AM
Demo Door Leaf not Frame
Thu, Nov 15, 2012 at 9:31:09 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
door frame off-set
Wed, Mar 11, 2015 at 7:42:20 AM
Door Frame
Tue, Sep 28, 2004 at 5:58:51 PM
new door in exisiting wall
Wed, Jan 9, 2008 at 4:40:50 PM
Page generation time: 0.2803
