18 Users Online (16 Members):
Forums >> Revit Building >> Tips & Tricks >> Can't read "Temp. Dims", too small?, change the size!
4 Posts No Rating |
Hi All.
I have always found that the "Temp. Dims are too small, when you use the Measure tool, always have to scroll up closer to read them!
The solution is in the "REVIT Options."
Go to the "Graphics Dialogue Box" and at the bottom you will find the "Temporary Dimension Text Appearance" Box
This is set to Size of "8 points", I now run at "14 Points" .
Soooo much betteeeeeer!
Albeys
Albeys.. if you had asked or searched in this forum, you had seen this:
- http://www.revitcity.com/forums.php?action=viewthread&thread_id=27256
- http://www.revitcity.com/forums.php?action=viewthread&thread_id=10467
- http://www.revitcity.com/forums.php?action=viewthread&thread_id=8133
4 Posts No Rating |
Hi TyPhoon.
I did not search through the forum for a solution to this, I was not looking for a solution to this feature, but it was anoying, then when I found the place where you can make the change, I thought I would put it up there for every one too.
I think that it is still a good tip; I might not be the first to discover it;
Albeys
Temp Dim's are too small |
Mon, Jul 30, 2007 at 10:36:05 PM
Plan Render-No "View Size"? |
Tue, Jan 13, 2009 at 4:25:21 PM
dimension graphical convensions |
Wed, Aug 30, 2006 at 3:38:25 PM
What's up with the tezt "size"????? [ 1 2 ] |
Tue, Aug 19, 2008 at 10:16:25 AM
25
I need to change my building levels from 0'-0" to 100'-0" |
Sat, Sep 11, 2010 at 8:03:55 PM
12
