Forums >> Revit Structure >> Technical Support >> SYMBOLIC LINES
Wed, Aug 15, 2012 at 11:10:27 AM | SYMBOLIC LINES
amolese
​Hi Guys How do I draw symbolic lines for a sliding door or sliding window in a revit family? Do I need to draw two oblique reference planes to host my arrow and lock my lines to the appropriate reference as also done for the model or is there any simpler way of doing this?
Wed, Aug 15, 2012 at 12:08:48 PM | SYMBOLIC LINES
No need for any of that.  Just go to the appropriate view - plan - elevation - section and draw the symbollic lines.  Lock them to any model components that are parametric or dimension form those elements or available ref planes if it is a parametric family.
Be aware that in elevation views, your symbollic linework might defaut t 3D.  Check that by looking in a 3D view.  If so, pick the lines in the appropriate view and pick the convert lines tab.
Thu, Aug 16, 2012 at 7:01:09 AM | SYMBOLIC LINES
amolese
Many Thanks WWHub. I have tried it as you suggested and it worked perfect.
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Symbolic Lines Variation in Family
Thu, Feb 15, 2007 at 1:33:21 PM
Page generation time: 0.5279
