Forums >> Revit Building >> Technical Support >> File size
Mon, Jan 9, 2006 at 2:35:26 AM | File size
cadjockey
Hi all, There is a utility that we are currently using with autocad called 'lfd' (layer filter delete) that dramatically reduces the file size of your drawing. Usually by 80% Is there something similar for revit? cadjockey
Mon, Jan 9, 2006 at 6:55:04 PM | RE: File size
eldados
eldados Avatar
4.5 Stars: 8 Votes
nope, the only thing you can do is purge your project of any unwanted families and delete all 3D views you don't really need... .rvt is already compressed AFAIK...
Integrator
KarelCAD
Tue, Jan 10, 2006 at 4:41:56 PM | RE: File size
arccodex1
3 Stars: 1 Votes
We've noticed that when Revit crashes the recovery file is a lot smaller than the original. There's probably a lot of extra data that even a purge can't get rid of.
Tue, Jan 10, 2006 at 4:55:35 PM | RE: File size
TomDorner
4.5 Stars: 25 Votes
With hard drives now going for less than a dollar a GB we simply no longer care. Tom
Tue, Jan 10, 2006 at 7:12:31 PM | RE: File size
arccodex1
3 Stars: 1 Votes
It usually only becomes an issue for us when we want to transfer the file over the internet.
Tue, Jan 10, 2006 at 8:55:59 PM | RE: File size
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit files are already compressed which you'll notice if you attempted to zip a revit file. There is usually minimal size reduction if any. You can also use the compace central file save option when use a multi-user project for archiving or sending of the web. HTH.
File size
Fri, Nov 16, 2007 at 2:43:48 PM
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:42 PM
decrease file size
Tue, Nov 16, 2010 at 2:06:43 PM
Saved File Size
Mon, Feb 15, 2010 at 6:17:13 AM
DWF File Size
Fri, Oct 26, 2007 at 9:52:18 AM
Page generation time: 2.5588
