7 Users Online (5 Members):
Forums >> Revit Structure >> Technical Support >> Copying Arch Wall Types
How can I copy some of the Architects wall types into my drawing?
I linked the revit drawing but the wall types are replaced with a generic 8". If I tell it to copy the wall types in under copy monitor then it unjoins all there walls and it messes the plan lines up.
Just thinking there should be an easy way.
Yeesh - Where is My Cad
Yeesh - Where is My Cad |
Oh yes - Revit 2012.
If you just link the model, then walls will be what the architect has. Otherwise, you can copy/monitor the walls and turn off the architect's walls. When you initiall start the copy/monitor, you have the option of defining what wall you use. If you have the generic 8", then you didn't follow that process. I suggest you read up on copy-monitor in your HELP.
Problems Copying Walls from Linked Arch Plans? |
Wed, Jul 15, 2009 at 4:23:32 PM
When I import REV. ARCH Link, it lands way outside my work space |
Fri, Oct 9, 2009 at 12:22:40 PM
Correct method for linking arch walls and my structure? |
Thu, Oct 28, 2010 at 11:33:24 AM
Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011) |
Fri, Jan 14, 2011 at 1:27:26 PM
How do I make custom wall types publicly accessible? |
Sun, Apr 4, 2010 at 2:17:08 PM
