Forums >> Revit Structure >> Technical Support >> Dimensionion "Canted" Beams
Fri, Aug 10, 2012 at 3:07:25 PM | Dimensionion "Canted" Beams
gregroberson
gregroberson Avatar
RST2103:
I have placed both beams and a beam system to the underside of a sloped floor.  I added the member, then selected the work plane by "choosing a plane" (the underside of the floor) from elevation view.  Went back to plan view and addded my elements.  However, I cannot add dimensions to the the elements.  Am I drawing the beams wrong?  I need the geloemtry and framing to be able to flex easily.
This is for a parking garage.  floor heights, bay widths, slopes. . . nothing is decided yet.  Iam i missing something obvious?
Greg
rotating "I-Beams"
Sat, May 6, 2006 at 1:26:49 AM
Beams connections - "soft", not sharp
Fri, Dec 7, 2012 at 9:06:42 AM
Canted beams (vertical axis following roof)
Mon, Jul 24, 2006 at 10:35:44 AM
Structural Beams Questions
Sat, Sep 8, 2007 at 1:48:33 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Page generation time: 1.4787
