14 Users Online (13 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Referenced Elev/Detail Bugs R-2012
Fri, Aug 10, 2012 at 12:38:15 PM | Referenced Elev/Detail Bugs R-2012
Madams
So I am running into a problem with the interior elevation bug not showing up when I reference an already created elevation, I'm using this as an "opposite" condition. It will show up fine in my "working view" but the coorisponding "sheeted view" it will not show. I've turned everything on, made sure no filters are being used and checked the worksets. I tried the same thing (referencing a simular view) with a detail gug and the same thing happens.
I even created a View Template from the view that is working fine, applied to the sheeted view and nothing.
It seems to me that when you are using the "Reference other view:" the bug acts like an anotation object (text or dim's) and doesn't carry through from view to view. Has anyone ran across this before?
Regards,Mike Adams
Fri, Aug 10, 2012 at 1:01:21 PM | Referenced Elev/Detail Bugs R-2012
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I think what you are refering to as a bug is actually what Revit is supposed to do. When you place an elevation, it is an intellegent object that controls another view with crop regions and view depth.
As soon as you click "reference other view" it does infact change to basically a 2d detail component which is using a simple parameter to copy some numbers; The intellegence is gone. Detail components are not intented to transfer from view to view.
You will have to place another "dummy" elevation mark in your other views.
Fri, Aug 10, 2012 at 1:05:46 PM | Referenced Elev/Detail Bugs R-2012
Madams
Thanks A-BIM.....it's not the anwer I wanted but it is the one I suspected. It just seems I haven'tran into this before.
Again, thanks
Note with a referenced view
Wed, Jun 29, 2011 at 1:32:52 PM
Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Wed, Nov 28, 2012 at 8:34:11 AM
Elevation bugs show up out side of Crop Region on sheets.. Why?
Wed, Sep 6, 2006 at 7:38:06 PM
Referenced views floating in space
Thu, Oct 22, 2015 at 2:43:48 PM
Detail - Reference Sheet & Detail - Choosing one I want
Mon, Jul 19, 2010 at 3:47:10 AM
Page generation time: 0.3287
