11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Overrides
208 Posts No Rating |
HI All,
I am familiar with the 'override host layers' and its ability to set pen weights across layers in section of an element. eg. a roof
However, I would like some elements within my project- that also have a number of layers eg. floor slabs - to be cut with different pen weights to what has been set within the override host layer table.
On the same view.
Is this possible?
cadjockey
PS: I have tried setting the element I wish to have cut differently with the 'by category' option on and set the pen weight for that object to what I would like.
It seems if I set an element up with an override the host layers overide settings are applied to all elements irrespective of whether the by category setting has been selected an object.
Post edited on 2006-01-08 22:46:37
Post edited on 2006-01-08 23:18:34
This is correct hence the "override" title.
To achieve what your after your would need to use the linework tool on those specific elements that are to differ...
that's right, the change is global...
Hi Guys,
I found a way to get around it but is means assigning a layer name that may not accurately represent the layer ie. instead of 'structure' you may need to use 'substrate'
By tweaking the combination in layer names and common edge settings for the objects you are able to show a roof in section with different penweights per layer to the floor in section on the same view.
I can now show a roof in section and only have the roof sheeting backlined in a 2 pen setting while the rafter beyond in a lighter pen and have my concrete floor slabs section in a 4 pen setting.
cadjockey
Phase Graphic Overrides |
Wed, Jul 10, 2019 at 4:01:45 PM
Visibility Graphics/Overrides COMPLETELY grayed out. Revit Structure 2013. |
Tue, Mar 27, 2018 at 3:22:42 PM
conflicting graphic overrides... |
Fri, Oct 12, 2012 at 10:44:04 AM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides |
Tue, Feb 10, 2009 at 2:19:03 PM
Model elements not displaying correctly |
Thu, Oct 27, 2016 at 9:10:19 AM
