12 Users Online (10 Members):
Forums >> Revit Systems >> Technical Support >> Walls not showing in MEP
13 Posts No Rating |
I have an existing project that I will be working in the next week or so. When I opened it I noticed that the walls are not displayed. I've gone through the VG but I can seem to figure out how to have them appear. I am working in REVIT MEP. I've noticed this in other projects as well. Alll the MEP systems wll be displayed but no walls. how do you host recpts, etc. without the walls?
set the discipline in the properties to coordination
Yes the view discipline is highly significant to walls.
Discipline - Architectural
All walls appear 'normally' (ie view range, object style and overrides)
Discipline - Structural
Bearing walls show normally
Non bearing walls do NOT show
Disciplne - Electrical
Walls appear halftone
Discipline - Mechanical
Disciplne - Coordination
Walls appear 'normally'
Edited on: Fri, Aug 10, 2012 at 1:02:06 PM
In shaded View walls/roofs are showing material and lines behind them |
Tue, May 28, 2013 at 9:35:44 AM
Walls not showing in plan region |
Mon, Feb 18, 2008 at 1:59:12 PM
14
Walls not showing in print |
Tue, Jun 14, 2022 at 9:51:43 PM
ID Numbers and Unasscoiated Families In Revit MEP |
Tue, Nov 29, 2011 at 12:12:18 PM
Can individual Objects be bound in Arch then changed in MEP |
Thu, Jun 7, 2012 at 1:37:23 PM
