17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> frieze board
I can't seem to figure out how to apply a frieze board along the rake of a gable roof. I tried a wall sweep, but that only gives horizontal. Anyone have an idea how to do this? Thanks
CREATE THE PROFILE YOU NEED AND USE HOST SWEEP --> FASCIA...
IF THAT DOESN'T WORK, YOU MIGHT HAVE TO USE IN PLACE FAMILY AND SET THE WORKPLANE TO THE ROOF ANGLE...
JUST LET US KNOW IF YOU HAVE PROBLEMS WITH THAT...
HTH
Host sweep is what I've tried, but it doesn't attach to the wall, just the roof edge. However, what I've done is to go ahead and do the fascia on the underside of the gable end and move it to the wall. Works pretty good, didn't know if there was something easier though.
if it works it works!
Roof eave/soffit gabled roof - RAC2008 |
Fri, Aug 24, 2007 at 7:09:29 AM
Fascia Board Too Long |
Tue, Nov 20, 2012 at 10:19:31 AM
Hardie Board Panels |
Wed, Sep 11, 2013 at 3:44:35 PM
Modifying walls sweeps |
Wed, Apr 30, 2008 at 9:44:15 PM
Timber External Cladding BOard / Weather Board |
Wed, Mar 31, 2010 at 10:02:29 AM
