Forums >> Revit Building >> Technical Support >> converting revit drawing into solid mass
Thu, Aug 9, 2012 at 9:32:27 AM | converting revit drawing into solid mass
fungry
Hey
i have abit of an odd question, i am wondering if there is an easy way to convert my revit drawing into just solid mass, i want to do this in order to make a OBJ file so i can do a 3D print??
the only way i can think about doing it is to export some 2D autocad files and make them up in sketchup!
you guys have anyover idea??
thanks for your reply in advance Smile
James
Fri, Aug 10, 2012 at 2:22:09 PM | converting revit drawing into solid mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not exactly sure what you are asking.  " if there is an easy way to convert my revit drawing into just solid mass" What are you trying to convert?
Fri, Aug 10, 2012 at 3:41:08 PM | converting revit drawing into solid mass
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
you may want to research exporting to STL format...
http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3Astlexporterforrevit%3Aen
I tried this once for a presentation and it didn't go well; my model was too detailed.
Converting AutoCAD 3d Solid in to a Revit Roof
Thu, Nov 17, 2011 at 2:47:17 PM
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
Making an object from solid mass...
Mon, Oct 25, 2010 at 7:17:06 AM
create floor or other solid mass from Topo
Wed, Oct 2, 2013 at 9:29:26 PM
Page generation time: 1.8508
