Forums >> Revit Building >> Technical Support >> Underlay as dashed lines 2012
Wed, Aug 8, 2012 at 11:56:19 PM | Underlay as dashed lines 2012
Pele
Pele Avatar
I would like to show my ground floor walls as dashed lines.
I read a post by Mr Spot in the search from 2006 but could not follow it is it different in 2012? can anyon help. please.
I have a 2 level apartment block & want to show the ground floor walls as dashed so that I can design the floor framing easier but do not want the grey lines of the current underlay getting mixed up with floor framing details.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Thu, Aug 9, 2012 at 12:08:11 AM | Underlay as dashed lines 2012
Pele
Pele Avatar
I have found the answer. Go to the manage tab & to drop down addditional settings where you will find halftone/underlay, in that dialog there are 3 parameter you can change, Weight - Pattern & Brightness.
Cheers Dermot
www.dmbd.net
Mon, Jun 17, 2013 at 6:56:19 PM | Underlay as dashed lines 2012
DFS2008
Excellent - exactly what I was searching for.  Thanks for your help.
Sun, Nov 24, 2013 at 7:46:31 PM | Underlay as dashed lines 2012
bonchaws
you can always go to the Modify tab > go to view> click on the line work  tool.
Highlight the lines you want to display differently and change the line type.
Sun, Nov 24, 2013 at 9:26:02 PM | Underlay as dashed lines 2012
Pele
Pele Avatar
The idea was to change the underlay line style as a whole format rather than just single lines.
Cheers Dermot
www.dmbd.net
How to show structure below dashed
Tue, Jan 10, 2006 at 9:27:02 PM
11
Disappearing dashed lines?
Tue, Feb 21, 2017 at 2:16:48 PM
Dashed lines in families are showing as solid lines in project
Thu, May 10, 2012 at 8:38:48 AM
dashed lines above cut plane
Fri, Jan 2, 2015 at 2:28:18 PM
Where is my underlay?
Fri, Mar 20, 2009 at 11:43:15 AM
Page generation time: 4.4324
