20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Single Timber stud to double stud wall doesnt wrap the plaster at the end.
6 Posts No Rating |
Hey everyone, just need a hand working out this little problem
Ive got a 70mm stud with two skins of 10mm plasterboard on either side. i would like to have a thicker wall on either side of an openning. ive tryed to create a new wall that is 140 thick with 'wrapping' turned on and a 70 mm wall with wrapping turnned on.... the best i could get it to look was having the plaster board warpping around the end of the 140 thick end. However the plaster wall doesnt want to join up with the 70mm wall plaster as can be seen in my next post
any help would be great. thanks, i am using revit 2012 arch. aswell
Peter
Edited on: Sun, Jun 16, 2013 at 1:20:43 AM
You explination is a little confusing. Try adding a picture what what you have and what you are trying to accomplish.
6 Posts No Rating |
Thanks heaps i attached a copy of the wall and opening in question.
Thanks the arrow is pointing to a bulkhead
what i need is the plaster board to wrap around the back of the double stud nib.
Thanks once again
Window Placement in Stud/Brick Veneer Wall [ 1 2 ] |
Wed, Feb 4, 2009 at 11:22:19 AM
15
Stud wall family help PLEASE.... |
Fri, May 9, 2008 at 1:09:58 PM
Architectural Columns as Pilasters |
Mon, May 30, 2016 at 11:58:25 AM
Revit 2012 - Where have my stud wall lines dissappeared to? |
Thu, May 3, 2012 at 12:57:17 PM
Showing HSS in stud wall |
Fri, Apr 18, 2008 at 3:22:24 PM
