Forums >> Revit Systems >> Technical Support >> Can you use an IFC file in a family. or use one like a family?
Mon, Aug 6, 2012 at 4:38:37 PM | Can you use an IFC file in a family. or use one like a family?
jcrocco
3 Stars: 1 Votes
I have a file from a sprinkler manufacturer that is an IFC file of a Fire pump.  I cant seem to really use it, as when I open it and save it as Revit, it only allows me to save it as a Revit file, not a family.  As such, I cant rotate it on the verticle plane.  I can change the elevation, and rotate it on the horizontal plane, but not the verticle plane.
It doesnt allow it to be saved as a family, and If I start a family, I cnat import it, or at least I dont know how to.
Any Ideas?
Tue, Aug 7, 2012 at 7:57:37 AM | Can you use an IFC file in a family. or use one like a family?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you try opening a family (the correct one) and then drag and drop the file into that family?
Tue, Aug 7, 2012 at 8:17:23 AM | Can you use an IFC file in a family. or use one like a family?
jcrocco
3 Stars: 1 Votes
No I didnt.  I didnt know that I could try drag and dropping.  Also, what do you mean openng the correct one?  I am trying to add a fire pump to my project file, like it was a family.  I tried to create a family and import it, but did not try D&D it in.
Tue, Aug 7, 2012 at 8:23:45 AM | Can you use an IFC file in a family. or use one like a family?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I mean open the correct family for what you are trying to bring in. Such as mechanical equipment/specialty equip etc.
Tue, Aug 7, 2012 at 8:28:14 AM | Can you use an IFC file in a family. or use one like a family?
jcrocco
3 Stars: 1 Votes
I did that, and it gave me an error saying "Failed to open document".
Tue, Aug 7, 2012 at 8:37:00 AM | Can you use an IFC file in a family. or use one like a family?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you read this in your Help file? Can you upload your file on here and I'll give it a shot but I'm not sure if it can be put into a family from what I have read.
http://docs.autodesk.com/REVIT/2010/ENU/Revit%20Architecture%202010%20Users%20Guide/RAC/index.html?url=WS73099cc142f487551e5a0cb10850d4cd7c-7bcf.htm,topicNumber=d0e119757
Tue, Aug 7, 2012 at 8:58:50 AM | Can you use an IFC file in a family. or use one like a family?
jcrocco
3 Stars: 1 Votes
Yes, I have read that, it seems Revit only tells you how to open an IFC, not really on how to use it.  Heres the file.
Tue, Aug 7, 2012 at 9:49:49 AM | Can you use an IFC file in a family. or use one like a family?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Nothing is attached
Tue, Aug 7, 2012 at 10:04:03 AM | Can you use an IFC file in a family. or use one like a family?
jcrocco
3 Stars: 1 Votes
Sorry, the file size was over 2 mb, but it didnt tell me it was too big when I uploaded it.
Tue, Aug 7, 2012 at 10:31:39 AM | Can you use an IFC file in a family. or use one like a family?
There is no error checking on the site for file size.  That is up to you to know.
Tue, Aug 7, 2012 at 10:41:13 AM | Can you use an IFC file in a family. or use one like a family?
jcrocco,
Have you thoroughly read the HELP items under:
Opening Industry Foundation Class (IFC) Files
Tue, Aug 7, 2012 at 3:52:44 PM | Can you use an IFC file in a family. or use one like a family?
jcrocco
3 Stars: 1 Votes
I did go thru it yes.  I did not get a class mapping file with the IFC file.  Still, I have not found anything that shows or explains how to use an IFC.  All it says is you can open it in revit, then save it as a revit file.  When I go to do that, all it allows me to do is save it as a project or template.  I open up the project, and I cant rotate it vertically.  Maybe there is a way to do that in revit, as I never have, but the plane is a horizontal plane.  can I rotate a plane to be verticle?  If so, then I can just do that.
Tue, Aug 7, 2012 at 3:58:57 PM | Can you use an IFC file in a family. or use one like a family?
#13
I don't think you can rotate it.  It is already based on horizontal I believe.  If that is not the case, then you probably have a bad IFC file or it was incorrectly made.
Tue, Aug 7, 2012 at 4:19:41 PM | Can you use an IFC file in a family. or use one like a family?
#14
jcrocco
3 Stars: 1 Votes
That could be, and since its my first time working with one, I dont know.  There were warnings that could be ignored when I opened it up, but the opbject seemed fine.
The following problems were encountered in the IFC file: The following IfcPolyLoop(s) did not have enough points after duplicates were removed and were ignored: #845 #845 #2399 #4883 #9365 #9401 #9413 #9467 #10181 #11063 #11111 #11165 #845 #845 #2399 #4883 #9365 #9401 #9413 #9467 #10181 #11063 #11111 #11165
It doesnt sound like a big deal, but maybe it is.
Tue, Aug 7, 2012 at 4:27:00 PM | Can you use an IFC file in a family. or use one like a family?
#15
jcrocco
3 Stars: 1 Votes
Heres the file, I zipped it, lets see if it works.
Revit Family Export to IFC
Fri, Nov 29, 2013 at 4:29:41 PM
IFC file import
Tue, Jul 26, 2011 at 3:15:08 AM
EMERGENCY. Can Someone please help? Issue: IFC File
Mon, Sep 22, 2014 at 10:02:32 AM
export IFC
Fri, Aug 23, 2013 at 1:57:00 AM
IFC detail drawing into Revit
Mon, Nov 25, 2013 at 2:31:31 AM
Page generation time: 1.0862
