Forums >> Revit Building >> Technical Support >> Dimensioning Custom Stairs
Mon, Aug 6, 2012 at 7:55:51 AM | Dimensioning Custom Stairs
zsigmond2b
Yikes!  I have this crazy stair, and need to dimension.  Using Revit 2013, I am unable to select parts of the stair and dimension.  I am able to select parallel lines and add dimensions to that, however, landings are not parallel and will not let me dimension.
Image attached.  Is there any way around exporting this to Autocad to dimension?  Any thoughts would be appreciated!
Mon, Aug 6, 2012 at 8:03:18 AM | Dimensioning Custom Stairs
You may have to place some detail lines overtop of some of those landing lines.  Then remember, you can parallel dimension from a line to a point, selecting the point using your tab key.
revit not drawing complete custom 3d stairs
Sat, Oct 3, 2015 at 4:17:54 PM
Custom stairs mess.
Thu, Oct 2, 2008 at 12:41:47 AM
cantilevered stone stairs
Thu, Feb 22, 2018 at 2:30:39 PM
Creating Custom Stairs From Scratch
Thu, Oct 30, 2008 at 1:55:49 PM
Detailing/dimensioning stairs and railings
Fri, Mar 16, 2007 at 2:14:13 PM
Page generation time: 2.9996
