Forums >> Revit Building >> Technical Support >> filter the elements in the model group
Fri, Aug 3, 2012 at 11:55:30 AM | filter the elements in the model group
diesellam
I try to isolate just the ceiling elements using the filter tool.
I found out that if the ceiling elements are in certain model groups, those can't be isolated and won't show up.
What's the best way to deal with it?  Do I have to ungroup them before filtering?
Wed, Aug 8, 2012 at 11:24:08 AM | filter the elements in the model group
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If the element you are trying to isolate is in a group you will have to edit the group and filter for the element.
Wed, Aug 8, 2012 at 12:24:14 PM | filter the elements in the model group
Sorry but this is not true.
You can use your tab key to select a grouped element and then you can use the eyeglasses to isolate them.  You can also find the family type in the family browser, right click and pick select all instances in view and then isolate them.
You can edit grouped element's family type anytime but to edit most instance based parameters, you have to edit the group, then the element.
Rotating 3D Elements all at once
Thu, Dec 8, 2016 at 6:51:20 PM
12
Filter turns everything off
Wed, Apr 19, 2017 at 9:25:54 AM
Converting Model Group to Link
Sun, Oct 23, 2016 at 4:58:40 PM
Copying elements from a linked architectural model into my host structural model
Thu, Feb 12, 2015 at 4:30:35 AM
Can you apply cost to a model group?
Wed, Aug 5, 2009 at 2:22:57 PM
Page generation time: 1.5216
