Forums >> Revit Building >> Technical Support >> The pattern with the values specified is too dense/too large
Fri, Aug 3, 2012 at 10:46:38 AM | The pattern with the values specified is too dense/too large
gizzledos
gizzledos Avatar
I'm trying to load this .pat file and no matter what I set the scale to it tells me it's either too dense or too large. If it's too dense revit suggests that I increase the line spacing, and if it's too large it recommends decreasing the line spacing. What can I do?
Thanks all
Fri, Aug 3, 2012 at 10:47:12 AM | The pattern with the values specified is too dense/too large
gizzledos
gizzledos Avatar
I am using Revit 2013.
Fri, Aug 3, 2012 at 11:41:09 AM | The pattern with the values specified is too dense/too large
That is a huge file!
Sorry - I think it is too complicated.
Fri, Aug 3, 2012 at 8:37:21 PM | The pattern with the values specified is too dense/too large
hugh
3.5 Stars: 4 Votes
Even AutoCAD struggles with that pattern definition which contains over 16,000 pattern definition lines and is an example of the bloat that can emerge from a runaway hatch pattern generator:
http://www.hatchkit.com.au/faq_detail.php?id=9
The pattern could be equally well defined with a pattern containing up to about 250 lines that would not unnecessarily burden your model. A 250 line pattern would occupy a file of the order of 20Kb instead of over 1Mb.
I suggest you find an alternative pattern either from the collection maintained on this forum or elsehere - we keep a list of hatch pattern related links here:
http://hatchkit.com.au/HatLinks.php
Hugh Adamson
www.hatchkit.com.au
Stone patterns - "the pattern with the values you have supplied is too large"
Mon, Dec 7, 2009 at 1:27:33 AM
Surface patterns too dense in oblique views
Wed, Aug 9, 2006 at 9:36:14 PM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
3d display question
Wed, Apr 15, 2009 at 3:09:11 PM
EDITTING FILL PATTERNS
Fri, Dec 9, 2005 at 2:19:45 PM
Page generation time: 1.6412
