Forums >> Revit Systems >> Technical Support >> The resulting angle between the segments is too great
Thu, Aug 2, 2012 at 10:25:05 AM | The resulting angle between the segments is too great
DanHaga
I am getting this error when trying to connect 2 pipes using the "Trim/Extend To Corner (TR)" command in Revit MEP 2012 and 2013.
Error: The resulting angle between the segments is too great.
Is there a way to change the angle that triggers this error?
I am creating as-built models of MEP spaces so my pipe runs aren't all straight and perfect like Revit wants them to be and I need to be able to connect pipes that are at off angles.  Take a 110 degree bend for example.  I know the generic elbow can handle this but how can I get Revit to insert it that way and bypass that error.
If I try and drag the pipe ends together I get the same error or this one "No auto-route solution was found".
Anyone have any suggestions or workarounds for this error other than manually placing elbows?  I would really like it to work with the Trim/Extend command.
Thanks
Fri, Aug 3, 2012 at 10:40:31 AM | The resulting angle between the segments is too great
sllana
5 Stars: 2 Votes
Yes, I saw one possible solution to that in a video. Extending the pipe much more than you need it, the trim is possible. Look at minute 5:00:
http://www.youtube.com/watch?v=AKksOWkS33g
Edited on: Fri, Aug 3, 2012 at 10:41:20 AM
Fri, Aug 3, 2012 at 10:48:07 AM | The resulting angle between the segments is too great
DanHaga
I'll try that.  In the meantime...
I have links for sample files files.
JPG: Lets call this the as-built.  This is what i want the Revit model to look like.
PCG: As-built scan data/pointcloud.  Insert into Revit Center-to-Center.
RVT: This is a revit file with standard pipes fit to the scan data.  All pipes are aligned and meet at the end points.  From this point I would like to be able to go in and simply use the TR command to connect the segments for a result that looks like the attached JPG.
Make sense?
Fri, Aug 3, 2012 at 12:30:28 PM | The resulting angle between the segments is too great
DanHaga
The over extending did not work.
Removing multiple curtain wall grid segments
Mon, Jun 13, 2016 at 9:53:15 PM
Removing Segments from a wall sweep
Mon, Jan 16, 2012 at 11:25:12 AM
Railing at an angle
Thu, Jun 7, 2007 at 8:36:35 PM
Rotation angle of double angle roof bracing.
Mon, Jan 21, 2008 at 2:51:55 PM
Family with angle parameters.....
Tue, Sep 18, 2012 at 8:43:04 AM
Page generation time: 1.6078
