Forums >> Revit Building >> Technical Support >> Exposed Rafters- Revit 2012
Thu, Aug 2, 2012 at 7:49:03 AM | Exposed Rafters- Revit 2012
fstop11
fstop11 Avatar
Ok guys, here's my situation. I have a project for a pavilion on a tennis court, concrete slab, 6 post and a asphalt shingle roof, nothing fancy. My problem is that I can't figure out how to properly draw the exposed rafters at their 12/6 or 26.6 degree pitch, which ever you prefer. I drew the rafters in "generic model," birdsmouth included, but the "Ref. level" does not give it any type of pitch. What am I missing?
Thu, Aug 2, 2012 at 8:52:27 AM | Exposed Rafters- Revit 2012
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Draw a reference plane at the level and angle that you want it at then when you set your rafter to that plane.  Or go to an elevation view and I think you can just move and rotate your rafter to the angle that you need
Thu, Aug 9, 2012 at 9:18:10 AM | Exposed Rafters- Revit 2012
fstop11
fstop11 Avatar
Thanks, that worked perfectly.
Roof Rafters exposed
Mon, Oct 1, 2007 at 9:08:11 AM
How to create Sloped Rafters with Various Rafter Tail Cuts
Mon, Jul 22, 2013 at 12:25:53 PM
Custom rafters/roofing Revit 2012
Wed, Oct 9, 2013 at 8:31:55 PM
Room Problem
Mon, Jan 23, 2012 at 4:22:25 PM
Joining sloped rafters to columns.
Thu, Mar 17, 2011 at 5:27:16 PM
Page generation time: 1.6009
