Forums >> Revit Building >> Technical Support >> Tricky Formula Question
Wed, Aug 1, 2012 at 4:51:27 PM | Tricky Formula Question
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I am creating a Detail Component that is a circle repeated along a line, with parametric spacing. For example, if I draw a 4' line, with 1/2" spacing, the circles run the full length at 1/2" intervals. If I change the spacing to 3", I still want them to run the full length, but the overall number to diminish so that they are now spread out across the same 4' line, but at 3" intervals.
I have almost got this working using circles grouped to detail lines, and then an array. It is ALMOST great, but I can't figure out the right formula for the number of circles so that they always draw the maximum number of circles that will fit in the length that I draw. If, for example, I do       (Length - Spacing) / Spacing + 1       then the number will round down and not always draw an extra one even though there is space. If I do           (Length / Spacing) + 1         then it will sometimes draw an extra hole BEYOND the length I have drawn.
If this makes any sense, what formula would I use?
Thanks.
Wed, Aug 1, 2012 at 5:28:51 PM | Tricky Formula Question
TKennedy
4 Stars: 8 Votes
I've run into the same problem, and it seems to come from Revit rounding integer parameters. I have a family that arrays table legs, and checks to see if Revit is rounding down when it's not supposed to (or rather when I don't want it to). I have attached the family along with a .txt file that explains how the parameters work.
Wed, Aug 1, 2012 at 5:30:13 PM | Tricky Formula Question
sllana
5 Stars: 2 Votes
I suggest you send the file you already started in order to study the case
Thu, Aug 2, 2012 at 8:26:33 AM | Tricky Formula Question
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I sat down and thought for a while about it and tried (length / spacing) + .5, and that worked perfectly. Thanks for your suggestions.
basic formula question regarding parameter use
Wed, Jun 16, 2010 at 5:34:23 PM
Tricky? Roof
Mon, Sep 24, 2018 at 2:12:05 PM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula
Fri, Mar 5, 2010 at 12:09:09 PM
Page generation time: 0.2190
