Forums >> Revit Building >> Technical Support >> Replacing Imported block with Native Revit RPC element
Wed, Aug 1, 2012 at 12:21:24 PM | Replacing Imported block with Native Revit RPC element
nijM
Hi all, I hope I'm not posting in the wrong place...
I have made a large urban model in sketchup and would like to render it using Revit 2012
In this model there are many "node" blocks which represent the coordinates of trees (scattered on the complex terrain),
what i'd like to do is to replace these nodes (that are instances of the same block) with Revit's RPC tree
Is there a way to do this?
-Thanks
NijM
RPC's won't render in 3DS Max after importing from Revit
Sat, Dec 17, 2005 at 9:10:50 AM
Rpc Creator made Rpc can't load
Wed, Oct 24, 2012 at 5:12:32 PM
ArchVision RPC Component not showing in Views only in Renders.
Fri, Sep 4, 2009 at 9:13:28 AM
tag an imported dwg title block
Thu, May 12, 2011 at 12:34:13 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Page generation time: 2.2144
