Forums >> Revit Systems >> Technical Support >> Schedule with mutilple discpline characteristics
Wed, Aug 1, 2012 at 8:50:27 AM | Schedule with mutilple discpline characteristics
heinzk1
We want to create a schedule for reference that shows the Type Mark, Mark, Electrical Panel, Circuit and Apparent Power.
Can this be done in Revit MEP 2012?
Ken
Wed, Aug 29, 2012 at 11:44:10 AM | Schedule with mutilple discpline characteristics
jlights
3 Stars: 2 Votes
Try creating a multi-category schedule, and make sure all the families you want displayed on the schedule have each of these parameters. Add filters to filter by Type Mark and Mark and Electrical Panel and Circuit and Apparent Power. As long as all these parameters are in each of the families, they will show up on the schedule.
Or you could create a schedule filter so that only families (regardless of category) that meet certain criteria show up on the schedule. For example, yo might create a shared parameter called Reference Schedule. You put this parameter in each family (it doesn't need to have a value) and you also put it in the schedule as a hidden field. Then on the schedule's filter tab, choose Filter By > Reference Schedule > exists.
jlights
How to change the name of discpline and sub discipline in revit project browser?
Tue, Jul 7, 2009 at 4:02:39 AM
Column cap visiblity
Thu, Oct 29, 2009 at 5:38:37 PM
Revit 2010 Stability
Wed, Jun 3, 2009 at 3:00:30 PM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
window schedule - skylights
Wed, Jun 7, 2006 at 10:00:02 AM
Page generation time: 0.1619
