Forums >> Revit Building >> Technical Support >> Masking Regions and Filled Regions BEHIND 3D Objects
Tue, Jul 31, 2012 at 10:21:23 PM | Masking Regions and Filled Regions BEHIND 3D Objects
Phaeax
Hi, we have been trying to do some quick and dirty drafting/ modeling due to time constraints on a projects. typically we would model everything accordingly but every once in a while you need to do it in an improper manner.
I have a filled region representing a decorative wainscot panel. I have furniture in front of this wainscot panel. The Furniture is in 3D and the Wainscot is being represented by a Filled Region in this case. For the life of me, I cannot get the Filled Region to "appear" behind the furniture without spending the time to edit the filled region boundaries.
Can I make a filled region, or a masking region appear behind 3D objects in Elevation, plans, etc. easily?
I am using Revit Architecture 2009 currently.
Thanks,
Wed, Aug 1, 2012 at 6:48:51 AM | Masking Regions and Filled Regions BEHIND 3D Objects
You never will.  Filled regions are not 3D - they are 2D.  You can only control front/back in relation to other 2D objects.
Wed, Aug 1, 2012 at 8:10:27 AM | Masking Regions and Filled Regions BEHIND 3D Objects
Phaeax
Thanks, I was afraid of that.
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Getting rid off masking regions?
Fri, Feb 4, 2011 at 4:12:56 AM
Masking and filled regions dont cover dimensions and tags??
Wed, Apr 9, 2008 at 11:12:17 AM
Filled Regions Not Masking?
Tue, May 12, 2009 at 5:45:16 PM
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:22 PM
Page generation time: 0.1588
