Forums >> Revit Building >> Technical Support >> Loading downloaded components into project
Tue, Jul 31, 2012 at 7:34:54 PM | Loading downloaded components into project
snacksandsnacks
This is probably a really simple question but I'm new to Revit, so I hope someone can help. I'm using Revit 2012.
When I open downloaded 3D components from RevitCity they appear as they did online. For example, a blue car looks exactly like a 3D blue car. But when I load the family into the project, the blue car is covered in a bunch of lines (the lines that make up the drawing, I assume). How do I adjust the settings so that the components just looks normal?
Wed, Aug 1, 2012 at 3:31:11 AM | Loading downloaded components into project
4 Stars: 205 Votes
In project you need to change the "Visual Style" to have the same effect, I believe you have your view in "hidden lines" style and not in shade or reallistic.
Wed, Aug 1, 2012 at 9:14:43 AM | Loading downloaded components into project
snacksandsnacks
Yes that was more or less it, thank you. I had to uncheck "show edges" in the visual style menu.
Problem loading components
Mon, Sep 28, 2009 at 3:43:40 AM
problem loading components
Sun, Apr 26, 2009 at 2:21:18 PM
LOADING DOWNLOADED FAMILIES
Mon, Feb 19, 2018 at 3:25:48 PM
Not All Downloaded Revit Families Appear After Loading
Sat, Mar 19, 2011 at 12:21:22 PM
version of components downloaded
Tue, Jul 16, 2013 at 3:44:50 PM
Page generation time: 2.1487
