Forums >> Revit Building >> Technical Support >> Visability parameter for dimensions
Tue, Jul 31, 2012 at 11:17:19 AM | Visability parameter for dimensions
broigutt
Hi
I was wondering if anyone knwos if there is possible to have a visability parameter for dimensions?
I have to make fabrication drawings for elements that i use alot in every project that i have given certain parameters.
I think there should be a way make the dimensions in the family editor and hava a visability parameter for if you want to show them or not because they are not shown on my details but i need them on the fabrication drawings
workaround would be appriciated
regards
Sigurjón
Tue, Jul 31, 2012 at 12:10:41 PM | Visability parameter for dimensions
You can not get the dimensions to show that I know of.... but if done properly, they can be scheduled.
Tue, Jul 31, 2012 at 12:17:05 PM | Visability parameter for dimensions
jlights
3 Stars: 2 Votes
Workaround idea: in your families, select the reference planes for the dimensions you will want to show in your detail views.  Make sure they are either named references (Front, Back, etc.) or Strong References (meaning you will be able to apply dimensions to these parts of the family while in the project view). Then you can dimension your details in the project easily. I don't think you Rolling Eyeseally* want family dimensions to show up in projects.
If you have details you'll use in multiple projects, try saving them to your project template, or to a separate project file that you use to store details, and then you can just import the detail view into whatever projects need them. HTH.
jlights
Visability Parameter is greyed out
Sat, Jan 24, 2015 at 4:10:27 PM
Dimension Visability in Dependant View
Wed, May 28, 2008 at 11:50:35 AM
Visability/ graphics
Tue, Mar 25, 2008 at 1:40:47 PM
Room Tag & Room Dimensions
Mon, Mar 13, 2006 at 3:11:05 PM
Yes No parameter with a value
Tue, Apr 13, 2010 at 7:56:19 AM
Page generation time: 0.2167
