Forums >> Revit Building >> Technical Support >> how to draw a simple fan
Tue, Jul 31, 2012 at 7:39:38 AM | how to draw a simple fan
frifer
5 Stars: 4 Votes
Hi guys! how can i draw a simple fan? just a cylinder with 6 blades. i have problems on finding out how to make the blades. tried extrusion, sweep multiple extrusions, but nothing made it. could somebody please give me some tipps or even better post a few screenshots on ho wto do it?
thank you very much!
ps: the blades MUST have an inclination just like real blades. extruding a "flower" is not a solution.. Smile
thanks
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Tue, Jul 31, 2012 at 7:56:19 AM | how to draw a simple fan
I don't believe revit is the program to do this, it is not an industrial design program.  You would be better off in sketchup like this one: http://sketchup.google.com/3dwarehouse/details?mid=419327cc99fdf6c43ab9904eea287f61&prevstart=0 then load that in a Revit family.
Tue, Jul 31, 2012 at 12:40:14 PM | how to draw a simple fan
4 Stars: 205 Votes
Check here too: http://www.greenheck.com/drawings/
Tue, Jul 31, 2012 at 3:18:09 PM | how to draw a simple fan
TKennedy
4 Stars: 8 Votes
Do they need to twist, or just rotated?
Wed, Aug 1, 2012 at 1:07:29 AM | how to draw a simple fan
frifer
5 Stars: 4 Votes
Hi guys!
thank you for all your answers hints links etc! Smile i am just missing one step: ppl say not to import autocad into revit, and you can read about it everywhere, but you say to do so anyway. quite sure that both of you are right, my question is WHEN do i import a cad file, when do i have to avoid it?
tkennedy, rotated is enough, no need to twist.. Smile
thanks guys!
Wed, Aug 1, 2012 at 7:09:26 AM | how to draw a simple fan
You said "...the blades MUST have an inclination just like real blades...".  If the rules now is that they don't need to be twisted but can be flat, then this is very easy to do in Revit.  Just extrude your blade in elevation, then from a perpindicular view, rotate it, then go back to the elevation and array it.
How do i put a ceiling fan on the ceiling?
Tue, Jun 26, 2018 at 3:43:23 PM
Anyone have a WALL-mounted Ceiling Fan Family?!
Wed, Sep 18, 2019 at 8:43:01 AM
Smoke & Fan symbols
Mon, Feb 2, 2004 at 1:34:57 PM
Ventilation fan 40000 CFM (rfa) required.
Fri, May 16, 2014 at 7:42:43 AM
How Do I draw this...?
Tue, Jul 22, 2014 at 3:25:16 AM
Page generation time: 2.5264
