Forums >> Revit Building >> Technical Support >> Can't create sweep
Mon, Jul 30, 2012 at 4:28:01 PM | Can't create sweep
grebnesor
Hi all,
Im trying to create some window mullions for a church in 2012 using a sweep, but for some reason the tight combination of curves keeps resulting in a 'cannot create sweep' error. any ideas on how i can fix this or otherwise get the result i'm looking for? I've attached an image of the path I'm trying to use.
109429_window_path.tiff
Tue, Jul 31, 2012 at 12:43:48 AM | Can't create sweep
rinesh355
rinesh355 Avatar
4 Stars: 5 Votes
Hi,
path is ok
in thi type of curve path, profile size and shape make problem on creating sweep, use simple profile for sweep, width of profile make a differece,
I have attached revit file ,using your curve path with simple profile
Tue, Jul 31, 2012 at 6:51:11 AM | Can't create sweep
If you are sweeping curves or angles, you should always try to have the path on the inside of the angle/curve.  Revit will not fold a sweep back on itself.
Tue, Jul 31, 2012 at 11:02:14 AM | Can't create sweep
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
"Keep the path on the inside of the curve". Great Tip.
Can't Create Sweep
Wed, Sep 20, 2006 at 2:39:47 PM
Sweep problem
Wed, May 21, 2014 at 9:21:16 AM
Sweep Question
Tue, Mar 7, 2006 at 3:01:15 PM
Having problems when trying to create a Steeple using Sweep
Wed, Apr 28, 2010 at 2:29:19 PM
11
Parametric sweep profile?
Mon, Jul 17, 2006 at 8:32:12 AM
Page generation time: 7.5047
