14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> HELP NEEDED - DIMENSIONS TO BEAMS LINKED IN FROM MULTIPLE REVIT FILES
4 Posts No Rating |
i'm using revit structure 2012, and i have a main file with multiple files linked in. i'm trying to dimension to the structural beams linked in but it will not allow me to pick the beams. at the bottom of the screen it says " select references, then click in empty space to place dimension." what does this mean and how can i get this to work. thanks
it says " select references, then click in empty space to place dimension." <<< This is the standard way of dimensioning. If you don't understand this, then you need to do some Revit tutorials on beginning Revit.
4 Posts No Rating |
I've taken tutorials and classes. my question is why i can't dimension to the linked in beams. why would it say this and not let me pick the beam to dimension to.
4 Posts No Rating |
Start from what you are dimensioning to, then use your tab key at the beam. You have to pick a beam reference.
If your linked file beams are not parallel with what you are dimensing to, then they will not dimension to that.
Dimensioning with linked DWG files |
Sat, Nov 12, 2011 at 4:20:06 PM
autocad linked files and refresh |
Tue, Apr 7, 2009 at 2:12:36 PM
Where has my Editing Multiple Dimensions capability gone!? |
Thu, Jul 24, 2008 at 1:06:16 PM
View Properties of Linked Revit Files |
Mon, Feb 15, 2010 at 9:56:22 PM
Manage Link - Reload From MULTIPLE FILES ! |
Wed, Dec 9, 2009 at 12:55:03 PM
