Forums >> Revit Structure >> Technical Support >> Mass concrete waist instead of sloping waist slab for staircase
Thu, Jul 26, 2012 at 3:55:02 AM | Solid base instead of sloping waist slab for staircase
satheeshbabu
Hi,
How to create solid base instead of sloping waist slab for staircase?
The base will be in "L" shape (Solid Base). Please refer the attached image.
I tried stair seperately and solid base seperately as a model-in-place component.
But I can't join both. The problem is the "joint geometry" tool is not working for stair and model-in-place component eventhough both are in the same material.
If you have any workaround, pls. reply me.
Thank you.
Edited on: Thu, Jul 26, 2012 at 4:07:24 AM
Edited on: Thu, Jul 26, 2012 at 4:10:26 AM
Edited on: Thu, Jul 26, 2012 at 4:11:31 AM
Thu, Jul 26, 2012 at 4:39:54 AM | Mass concrete waist instead of sloping waist slab for staircase
4 Stars: 205 Votes
Create "Walls" around the stair or create an "In-place" solid like you are doing and because you can't use the Join geometry tool between them use the "linework" tool to "clean" the join lines, you'll need to do this in any view you want but when you render will look fine.
Thu, Jul 26, 2012 at 5:22:00 AM | Mass concrete waist instead of sloping waist slab for staircase
satheeshbabu
Thank you for your response, Typhoon.
When I use multiple copy of In-place, It will duplicate the components.
Then there are many model-in-place components and that will increase the file size. That is why i try to avoid model-in-place.
But in this case, no choice. As you mentioned, I will use the "Linework" to clean join line in each view.
Thanks again. Smile
Thu, Jul 26, 2012 at 3:58:23 PM | Mass concrete waist instead of sloping waist slab for staircase
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
have you tried using a family for the stairs instead on the stair tool?
try this....http://www.revitcity.com/downloads.php?action=view&object_id=11277
Staircase - Issues with Plan Graphics/Representation.
Sat, Sep 18, 2010 at 11:54:22 PM
double prints
Tue, Apr 8, 2014 at 7:59:43 PM
Stairs by sketch breaking
Sun, Mar 9, 2014 at 4:16:34 PM
RC Staircase and Levelling Concrete Issue
Fri, Aug 12, 2016 at 7:21:05 AM
Sloping Roof Elements Individually
Fri, Jul 11, 2014 at 9:49:46 AM
Page generation time: 0.2059
